Hi! I am relatively new at EPANET. I have been working on a system that was already built but didn't run, doing some research I found out that there were some issues with the pumps (the pump curve was not accurate),so I fixed those (I included the right pump curve). There are two wells on this system (modeled using a reservoir + a pump) each pump has its own pump curve. Once I fixed the pump curves, the system only runs if I leave one pump open and the other pump closed, I was wondering if any of you could help me understand why is that happening? what does it means to have one pump on and the other off? I have been searching on-line but have not been able to find the logic.
Thank you very much for your help, have a wonderful day
