Hello to all!
I have a question regarding enthalpy calculation... I am trying to do some exergy analysis and I need to have exact enthalpy values... which values for cp,air cp,wv and r (h=cp,a*T+w(r+cp,wv*T)) do I need to use to get exact enthalpy values for moist air (compared to ashrae tables)? using suggested approximate values cp,air=1,006 co,wv=1,86 and r=2501 i get slightly different results than values in ashrae table - error is +/- 0,1 but this can result in a significant error in exergy efficiency in some cases (exergy efficiency larger than 1). I ruled out other possible causes for this...
i tried to get polinomal equations for dry and saturated air enthalpy (form ashrae table) but i do not get good results with excel.. because i need to calculate a lot of different cases, calculating moist air enthalpy 'by hand' from ashrae tables would take A LOT of time...
i hope i was cleat what i need to do
thanks!
thanks!
