ENGINEERING PRODUCTIVITY
keenkeem
PH
I had just downloaded a program and am having hard time pasting loads to be used for my column investigation. The tedious process involves switching applications from time to time, copying loads at pasting it back to program. Each column is subjected to 5 load combinations and each load reactions has to be pasted onto the program. I had to switch and paste 10250 load reactions and I had second thoughts about doing it. Any applications out there that i could use that you would want to recommend? BETTER MACRoS? tips? I
