Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
High pressure rotor of turbofan engine (mixed flow type/medium bypass ratio) was found to have seized during third start attempt subsequent to two hot start ,however after engine has cooled down it was started successfully. do you have any idea on causes of the event?Based on a one line question with Zero other details, the answer, rather unsurprisingly is no.
Turny part is high pressure spool which comprises high pressure turbine blades so one malfunction scenario is the blade tip rub that is caused by excessive differential expansion of the rotor spool and casing components during hot starts. I ask about any other possible scenarios.That cause was that the turny part couldn't turn anymore.
Engine model: Tay650Have you asked the manufacturer?
I mean really, you don't say whose engine, which one, how old, why did it fail to start twice?
Clearly something is rubbing / expanding more than it should but what only god and a boroscope will tell you.
This is really like asking someone " My car wouldn't start this morning, Any idea why?"
TSN/CSN=35277/36724OP
Was the proper procedure used to start the engine. Before running hot.
Obtain from the manufacture for proper start up. A hot start up will void warranty and damage components.
How many hours has the engine cycled.
Was it due for inspection. Which is a complete tear down and inspection.
Take pictures as it is disassemble to decipher the issue.
TSN/CSN=35277/36724
I concur with youConfidentially I would neither assume nor presume that successful starting after cooling down means everything is now OK.
Much obligedOther possible scenarios - oil pump cavitating and bearings seizing during hot start.
You can not identify the root cause of occurrences through merely consulting fault isolation section of the MM, 8D is a recognized method for RCA in which D1:use a team that is selecting and establishing a team of people with relevant knowledge.....Why would you come to this corner of the internet to ask this question ? Your first stop should be the Engine manufacturer's Maintenance Manual or their customer support "help desk". If you are trying to learn, then consult the MM ... it'll include a lot of trouble shooting, or talk to the engine mechanic.
Ta muchlyGreen
I am not an expert. But studied why turbo prop engines fail. During start up the engine is required to warm up to allow all the internal components. To thermally expand.
It is known the to quick to high rpm causes damage do to stress from un equal thermal expansion.
