msquared48
- Aug 7, 2007
- 14,745
We are using the General Footing module in the Enercalc program to check the design of a spread footing.
Project description is a square spread footing with a square pedestal centered on the footing. Gravity load plus shear and moment from wind load are applied at the top of the pedestal. The overturning and sliding stability tab on the Results page give safety factors against both sliding and overturning as one would expect.
Confusion arises when looking at the detailed report with the report preview function because the detailed report says that there is no sliding, and there is no overturning for the footing. The help file for this module does not explain the report at all.
Does anyone know why the module calculates sliding and overturning safety factors, but the detailed report says there is neither sliding nor overturning?
Thank you.
Mike McCann
MMC Engineering
Thank you.
Mike McCann
MMC Engineering
