beachcomber
When a section line does not extend all the way across a part SE (V20) generates a line across the edge of the section, as if it was the edge of the part. Is there a way to get rid of this line (other than hiding the edge)?
Similarly, when you create a stepped section, lines are generated across the section at each step point. Is there also a way of getting rid of these?
I thought the second one was by setting "Show Edges Created By Cutting Plane Line Vertices" to off on the view properties > advanced tab, but it seems to make no difference. They are always created.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
bc.
Quadro FX4600.
