to all,
I have an motor assembly with and End Shield machining customer rabbet with a shaft extension thru the end shield.
The A datum in the shaft extension diameter, and datum B is the customer machined diameter bottom surface.
Someone put a GTOL of | position | .006 | A | B |
I want to change it to | concentricity | .006 | A |
Is this an accurate GTOL to change to ?
Mark
Mark
