In our repair shop a customer brought SIEMENS brushless servomotor with permanent magnet rotor.
They disassembled the whole motor, but only the brake seemed to had a problem, we rewind it and since then the system works again, but now the motor is heating, 90 degrees Celsius frame temperature.
The stator winding is with perfect insulation 4000Mohms and same resistance of the coils
They doubt in the encoder (attached you will find photos). They bringed a second one smaller WORKING, with the same encoder.
Now they want to replace the encoders of the motors. I have two questions:
1) Is there any special way to place the encoder in exact position or it doesnt matter?
2) Do you think that the encoder could be the heating reason?
Thank you in advance for your answers!
