Encampment deterrent for steel girder bridge
tmalik3156
CA
Good day all.
Looking for something similar as shown in the photo below for concrete girders, except that ours is for a steel girder bridge.
We don't want to drill holes to the steel girder webs.
Does anyone have drawings / photos / ideas about how to install such a cage for steel bridges?
Thank you
Why would you want to avoid drilling holes in the webs? We do it all the time. About the only thing that's usually restricted is welding to the flanges.
Make a semi integral abutment or just weld a stiffer and bolt to it
Thank you for your replies.
@BridgeSmith: Near the abutment, the web is subjected to the highest shear, so we thought drilling holes into webs wouldn't be a good idea. We wanted to do something less intrusive.
@jhnblgr: Well, the bridge is already there, and it's girder-on-bearing type bridge. Near abutment, existing stiffeners are resisting high shear, so we didn't want to modify them. Adding new stiffener would require welding to the existing girder.
The kind of grating attachment shown in the photo may also have a fatigue / durability concern. The upper part moves with the thermal expansion / contraction of the girder, but the lower part is attached to the abutment which is fixed to the ground. We want avoid that as well.
Our bridge does have Chevron-bracing diaphragms between girders. May be our best option will be to hang those gratings from the diaphragms.
Are you really that close to the shear capacity that a 1-2% reduction would create a critical load case?
Stiffeners provide most of their shear resistance by preventing the web from buckling. The minority contribution of the stiffener itself is reduced very little, if at all by having bolt holes in it. If you run through the calcs in the AASHTO bridge design spec, I'm fairly confident you'll find that the presence of a hole the size that you would need to attach the fence would not reduce the shear capacity.
@BridgeSmith
You are right that there shouldn't be any significant reduction in capacity.
The owner is just trying to keep homeless people away. Since this is not a bridge structural retrofit work, they prefer that girders are not affected.
If we can clip and secure the grillage on the cross diaphragm between the girders, this would likely be a more acceptable option to the owner.
In that case, it looks like you're stuck with beam clamps to attach the fence.
How about attaching the frame of the cage to the bottom of the deck and face of abutment seat? Some simple expansion anchors should work.
Thank you gentlemen. We will explore your suggestions.
