emergency venting capacity 1
Rony_2012
AU
Hi
I am currently working on spirit tank design. and need to put emergency vent, but I am not sure how to choose the emergency vent and pressure-vacuum vent for there.
I am using AS1940:2017
can anyone suggest how to choose the emergency vent for my tank and tank details, 3m diameter, and 5m height and how many vents should be considered for the particular tank.
thanks, in advance.
Choose?
Do mean size?
Try API 2000?
You need to know the volumetric or mass flow requirements from process calculations / fire case.
normally vents are only on the top but we have no information other than size for this tank....
I'm not familiar with the AS.
Otherwise, API 2000 would be used.
You will need to know, or derive, the allowable pressures for the tank in question; also flow rates and product properties.
For a smaller tank like that, it may be feasible to combine emergency and normal venting into one pressure/vacuum vent rather than having separate fittings for the two functions.
