I want to put hard wired emergency generators at wastewater several wastewater pump stations.
The problem is that the industrial grade generators are too big.
For example,
a seven lot subdivision, pump station has two 5 hp pumps and they never both run at the same time. The actual KW that I need to power is about 4 but the smallest industrial generator is around 25 KW.
Has anyone had any experience with putting an appropriately sized residential generator (12-15 KW range) at wastewater pump stations?
What's the down side?
For example,
