1
- #1
I'm new to this forum, and I can't find the code reference I'm looking for. A little background: We have a generator room that is using unconditioned outside air for cooling and combustion air, powered in using fans. There are three (3) generators in the room. I have a good idea of the airflow required, and selected my fans appropriately. However, I know there needs to be a discharge damper on the outlet of the fans. Through using projects with similar scope around the office, I saw that the requirement for the motorized discharge damper is "spring open/power close" as opposed to most dampers on the market. I received a submittal that shows "spring close/power open" which is opposite of what I specified. I seem to remember seeing the "spring open/power close" requirement in NFPA something or another. I haven't been able to find it in NFPA 110, 90, 92, or 70. Any ideas where I could find this control damper requirement, or am I just making this thing up?
