Hello!
I know that in an external floating roof tank, the minimum-size primary roof drain shall be capable of preventing the roof from accumulating a water level greater than design at the maximum rainfall rate. Normally this primary drain is placed in the central point of the roof and it can be a hose.
Also, the emergency drains are installed to keep water to a lesser volume that the roofs will safely support. Such emergency drains shall not allow the product to flow onto the roof.
If we have the primary roof drain, is it necessary to install those emergency drains? I think, the function is the same.
