I need to minimize the etching effect on the surface of treated A316L, which is cleaned with various electrochemical processes.
I work on a new treatment for stainless steel used for luxury accessories (high-end watch bands). The standard steel (Aisi 316L) has a nickel content (12%) which imparts the material a bright silver-white color when mirror polished. Unfortunately the treated material has a very slight yellowish appearance (invisible to the untrained eye), which is a no-no in the industry.
The treatment diffuses carbon under the surface, for 15-30 micrometers (depending on the treatment). According to the literature available, the carbon implants itself as FCC lattice. This strains the surface and imparts hardness. Unfortunately the material needs to be cleaned to give it back its lustre. One of these post-treatments uses a solution of HNO3 with traces of HF; HF may be needed because, during pre-processing for the hardening treatment, the steel receives a metal fluoride layer.
The surface resulting from post-treatment shows the structure of the crystals, which is detrimental to the mirror-polish finishing. Under the microscope the surface appears similar to what is observed after etching for crystal structure study. I was wondering whether there are chemicals that etch the surface in a more uniform way, avoiding the creation of micro steps between one crystal and the other.
