Elevations
goodtruant
Materials
Jul 22, 2011
82
How do I make a drawing elevation of a room?
Of course SWX Drawings wants to do exterior elevations of the walls. I want interior elevations, which I can do with section views.
1. Is there a way just to get an elevation without having to create a section?
2. If I must use the section method, how do I rename the view? I do not want my view callouts to say "Section - A", I need them to say "North Elevation".
Thanks!
-or-
Create each elevation as a separate body in a multi-body part or a separate part in an assy, then show each elevation in a configuration.
I created a annotation view, how do I insert it in to the assembly drawing?
goodtruant,
Model each wall as a separate part or assembly. Hide the part or assembly on your drawing view.
JHG
I figured it out....had to insert the elevation view first, and then hide it.
I still do not understand how the views are named. When I pull in the annotative views, it uses the standard format. "View A-A".
So if I named the view "Cabinet Section", the view label changes to "View Cabinet-Cabinet".
There are two ways in the drawing without any other preparation:
In a drawing of an assembly you can create a hiding plane that will hide everything in front of it. Removed section will work nicely for this. It can all be done in the drawing.
In a drawing you can tell a view not to display certain components. Hide the components in the foreground revealing the inside elevation.
TOP
CSWP, BSSE
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
