Sparky1949
Petroleum
This tank is adjacent to a steep road. When it overflows, the water makes the road dangerous.
The owner wants an alarm indication when the tower overflows. Currently, there is a pressure gauge operated alarm which is not reliable due to the distance from the tank and the elevation. As the water temperature changes, the alarm either sounds when there is no overflow or fails to sound when water is overflowing. (Yes, it has been calibrated.)
Due to icing in the tank, I am thinking of putting a paddle switch outdoors on the end of the overflow pipe after the varmint screen. The only problem that I see is that the paddle will be exposed to vandalism. Is there a common practice for this situation?
