Please see the attached sketch for a description. It’s for a field house, 130’ wide with long span truss/joists. There is going to be an elevated running track all around the field house. The track is 10’ wide and will consist of concrete on metal deck or composite construction, whichever works out better. The track is to be supported by precast wall on one side and is to be hung from the joists on the other end.
The architect has experience designing a similar facility that was built several years ago (I received the existing drawings from the arch). I asked if there have been any problems with the track and he is not aware of any.
I am not sure about this detail. The track is to be connected to a rigid wall on one side and is to be hung from a joist that will deflect on the other end. The fact that the joist will be built with camber and then will deflect differently under live loads makes me somewhat nervous about this arrangement.
The other question I have as in regards to the live load for the track. Is 100 psf (gymnasiums) adequate or should it be higher or include some impact factor?
