Hi all,
I have a little problem. I'M using MSC Patran and I realized that when I'm meshing, the coordinates system of my different sections of meshing are not oriented the same way. Is there any way to just modify the orientation of the element?
Or, when I'm accessing the results. I can make a z stress component Quick plot that will be different from a z stress component Fringe Plot. As I understand, Fringe plot the results from Nastran as is, so in the material or element coordinate system. Quick plot is suppose to plot the result in the basic coordinate system. But the relation between the two doesn't fit. For example, let say that the element Z coordinate correspont to the basic X coordinate. So by making a fringe plot of the z component, I should get the same result is I'm making a Quick plot of the X component. But it doesn't work.
Any clue how to solve this?
Thanks.
Thanks.
