I have two situations, in an upcoming design, where CP2 Ti will touch Stainless 304.
1) In an outdoor (wet) environment electro-polished CP2 Ti is bolted to 304 Stainless steel plates about 2 sq. ft. surface area. Does the electro-polishing provide any corrosion protection or should I separate the plates with an insulator of some type (suggestions)?
2) Inside a dry bearing housing made of CP2 Ti, the outer races of 304 Stainless steel bearings, and retaining clips come in contact with the housing. If kept dry is this a problem? Or, again, should some type of insulating paste be used (suggestions)?
