CBravo
- Sep 10, 2007
- 15
Our plant is undergoing a lighting upgrade to T8 fixtures from MH fixtures. All is well in the front of the plant where the lighting uses one 480 VAC phase to neutral at 277 VAC.
The ballasts are rated to work form 120 to 300 VAC. No taps, they are intellivolt electronic ballasts.
The ballasts are failing in the installation in the addition out back where the lighing uses two hots at 208 VAC.
The electrical contractor is suggesting running a neutral conductor to all the fixtures for 120 VAC operation.
How does the intellivolt ballast know if it has a neutral connection or not? Is something fishy here?
Thanks.
Thanks.
