Electronic Active Noise Cancellation
drawoh
8,958
I am being asked about this. We are building a workstation in our factory that will be noisy, perhaps around 110dB. We are installing sound insulation. The racket will kind of scatter around our plant. Apparently, we can install a speaker system that will monitor the noise and emit reverse sound waves to cancel everything.
Has anyone got experience with this stuff? Will it work for people scattered around a fairly large work area?
JHG
There are companies that specialize in this work.
It works much better if the sound is from a concentrated area.
Often you have to build an enclosure in order to implement this.
Yes I used to do ANC. Unless things have changed a lot then no it won't work over a broad area unless you can locate the speaker near the source, or a mic and speaker near each worker. It also needs a feedforward signal ideally to drive it. If the noise is not periodic then I think you've little chance of cancelling it effectively.
Interesting science project though.
Cheers
Greg Locock
AFAIK it won't work as it requires providing anti-phase and matching amplitude. This is tough enough with headphones when there it just a small hole leading into the ear to take care of.
Anti-echo sound absorption is the most effective approach short of building a box around the workstation and filling it all with concrete. I understand this may interfere with the work.
Yes, it can work in the right applications. It's most effective for steady-state periodic sources; e.g. rotating equipment, electrical hum, flow induced. Less so for sharp transients and impact noise.
The approach would be to cancel noise at the source.
A Google search for industrial active noise cancellation will turn up the leaders, including companies that can help you design a combination of passive and active noise control.
We did a tonne of work on this on the DHC8. As 3DD says matching opposing waveforms. The co9mpany we worked with was Ultra (in the UK).
