panou
- Apr 21, 2005
- 33
Hello
I have to install flowmeters in PPE pipes for measuring the flow of HCl(hydrochloric acid) 35%. Should i install the grounding rings as the manufacturer suggest? And also what is the straight unimpeded run at the inlet of the flow sensor? The manufacturer suggest 5xD (sensor diameter). Thanks in advance for your time.
