Hi MWellborn
If the "nuclear device" don't work, try the "MOAB".that oughta do it.Kidding aside.
I think a source of HI-voltage from a taser or other, could kill ignition fairly easy.As for the Battery
itself,without direct physical contact with it,I can't see a way of snuffing it out.(my car does it quite regularly without much problem)
If you reverse charge your car battery,you will be walking or on to a recharge station.
You probably had something else in mind !
GusD
