maniachalengineer
I'm looking for a small diameter carbon fiber thread supplier or source that makes and sells a "sewing?" thread that is electrically conductive with considerable resistance. I've ordered a 1 lb spool of "carbon fiber graphite yarn tow" from Aircraft spruce and Specialties- this is typically used for winding and fabricating various carbon fiber structures/reinforcements and it measures about 12 Ohms per ft. I'm looking for something much smaller and thus with much higher electrical resistance, approx 500k Ohms per ft.
Ideally the "thread" material will be flexible and multi-stranded for reliability during flexing and build operations. I anticipate needing to coat or protect the carbon "conductors" using a dipped/sprayed conformal coating or polymer sheath- but maybe somebody already makes a small diameter "high resistance" wire? Spark plug wires are similar today- but the insulation diameter is huge and the spark plug wire is not always continuous to DC voltage but relies on "spark gap jumps" to work properly.
My application involves using the wires in RF fields where high DC resistance appears "invisible" and does not perturb the various RF fields. Definitely very low voltages and currents only. I've seen a bit of mention online about MRI catheter wires using carbon but no supplier, etc.. I'd like to find a cheap, high volume material/source for this application. Seems like I've seen what looked like tiny carbon/cotton/polyester "wires" used for microphones, telephones, and USB in the past- but I simply cannot find any current (domestic USA) suppliers after considerable searching. Any ideas out there?
I'd also consider a small 2D or "flat" carbon or vacuum deposited conductive tape if it is available and has similar properties.
Thanks in advance for your suggestions and comments!
