Helepolis
- Dec 13, 2015
- 207
Hi to all,
I want to make a custom electrical spring contact.
From what i know the material used for electrical spring contacts is some kind of Ti-Cu alloy (couldn't find anything specific) and i was wondering if it is possible to match, to some degree, the properties of commercial spring steel (or any other suitable, not to costly, material) to the Ti-Cu alloy properties, especially the elasticity.
I'm asking because i got a prototype of the spring contact made from Nickel Plated Spring Steel but the material is too brittle for the application i need, and i fiddled with Shield Finger contact and although it is only 0.1 mm thick the part is very elastic and robust, as it is paper thin and makes the impression that it will crumple as soon as you touch it.
Thanks.
Thanks.
