Hello All,
Do you think it is possible to switch a conventional 1st stage separator with an electrical oil dehydrator? the dehydrator is 6 times bigger but I do not find technical information about its limitations. I mean what is the main characteristic of this type of vessel? The only info I have is the design pressure, the 1st stage separator can handle 3 times higher pressure. Possibly higher gas rates will have to be handled.
Thanks in advance,
Petroleo
Thanks in advance,
Petroleo
