Hello All,
hope everybody is fine.
If I have posted in the wrong section, I do apologize, just suggest me the right one.
Please, I would like to share with you following odd experience I am facing.
I have utilized two AC 220V fans.
One of them is from 2015, the other is recently manufactured.
They have got the same label name and, after a visual inspection they seem identical.
Same blade, same condenser.
I have tested them in the same electrical feeding condition, stabilized by a voltage stabilizer.
The same air flow and electrical consumption is absolutely comparable.
Nonetheless, the recent one produces a more grave sound
I tested them on the same application, so that I would exclude phenomena as aeolian sound or similar.
The sound is disappearing once I reduce the voltage.
Following are my questions
- Have ever any of you experienced something similar ?
- could this difference be generated by a different material utilized in rotor in stator ? Unfortunately my knowledge is not deep in this specific subject, so that I would assume that since they utilize copper, It would not affect
In other words, may the copper type have influence on the generated noise ?
- please, have you got any other ideas ?
I thank you in advance for any suggestion
