Is there a way to change classifications by adding air flow?
We have a new Kiln dryer for concrete going in. The unit itself is located in a 40' container with louvers on the doors. The burner itself is fed by natural gas. There aren't fans feeding air into the container so its just the air coming in from the louvers. Is this considered a class 1 div 1 area? Is there a way to change the class by adding a certain amount of airflow through the container? There is a burner gas valve and burner controls. I have attached a few drawings.
