"OUR NEW 2007 ESC ELECTRIC LINE OF SUPERCHARGERS HAS THREE MODELS. RATED AT 250, 500, AND 750 CFM, THE ESC-250CM, 500CM, AND 750CM WILL FIT ENGINES FROM 1000CC UP TO 500 CID BIG BLOCKS. OUR ELECTRIC MOTORS ARE NOW 80-90% EFFICIENT AND SPIN THE SUPERCHARGERS WITH SHAFT RATINGS OF 6HP @ 24 VOLTS UP TO 26HP @ 72 VOLTS. EACH 1000CC REQUIRES 3.5HP, SO WE COVER EVERY CONCEIVABLE ENGINE SIZE WITH OUR NEW LINEUP. STARTING AT ONLY $1695, THESE ARE THE LATEST TECHNOLOGY IN THE AREA OF ELECTRIC SUPERCHARGING. IDEAL FOR HYBRID VEHICLES AS WELL."
Even though the electric "turbo" we used was probably a different design, it was incredibly powerful. The REP fired it up in the main office. Though aimed at an open door 10 feet away, it still cleared all the papers off several desks. The thing I would question most is electrical reserves vs desired duty cycle.
BTW, the one we tried worked in parallel with the OEM turbo. It used a simple flapper valve on the output side of the OEM turbo. The electric unit came on as soon at the throttle was pushed, moved the flapper, and simply out blew the OEM turbo until OEM boost came up. When this happened the flapper would move back and the electric unit would shut off till next time. Worked great, but even with an automatic transmission it used too much electricity for commercial city driving.
