ErAmirKhan
Hello Everyone,
I am working on a project where I will be using electric motor aa driver.....but the motor output torque is low and for that I will be attaching planetary gearbox to multiply torque... Now the problem is I'm unsure about the motor output torque... I'm using one angle grinder motor and the specifications are attached in the file below...there are 2 powers input and rated and one torque is mentioned in the specifications If I cross check the speed using following formula
P=2πNT/60
The speed I'm getting is not matching with the speeds mentioned in the specifications... I have checked it with 1600 watts and 14Nm torque and 2400 watts and 14 Nm torque, And the speed I'm getting is 1090 rpm and 1637 rpm for 1600 and 2400 power respectively.
Pls help what I'm doing wrong as I'm new to electric motors
P=2πNT/60
