jrw501
- Mar 2, 2009
- 85
Does anyone here have experience designing elastomeric seismic isolation bearings with bolted connections (or doweled) I guess? If so, I was wondering how you go about checking stability at design/maximum displacement levels. For doweled connections you have rollover to consider as well, but I am primarily interested in regard to buckling.
Do you use AASHTO or other codes/specs? I'm more interested in the application to buildings, but 17.2.4.6 in ASCE 7-05 just basically states, "each element of the isolation system shall be designed to be stable under the design vertical load where subjected to a horizontal displacement equal to the total maximum displacement"
Thanks.
Thanks.
