All,
I have an application where we are experiencing premature pump / motor coupling failures. We are using a Hytrel elastomeric toothed, shear, sleeve and flange coupling. The motor is equipped with a VFD that operates in steps starting at 3600rpm then steps down to 2700rpm then to 1800rpm. The motor nameplate Hp is 60 but never gets over 45 during operation.
We had a recent coupling failure where the elastomeric coupling melted. I have read that VFD’s will produce torsional pulses at low speed greater than those at high speeds. I have also read that heat can be generated through the effects of vibration and hysteresis of the elastomeric coupling sleeve.
Is it possible that when the VFD is operating at the lower speed the vibratory pulses are generating enough vibration for hysteresis heat to be an issue?
Any feedback is greatly appreciated.
