Elastic wave amplitude
WARose
As I have mentioned on other threads on this board: I have been reading several texts on the propagation of elastic waves in isotropic media lately. (And I appreciate the discussions we’ve had here on this topic.) If I could prevail upon someone again……..a question crossed my mind this weekend………….
In a lot of the afore mentioned texts……equations defining the motion of a variety of wave types are given. (I.e. Rayleigh, lamb, P-wave, etc, etc.) But one thing I am noticing in a lot of them is: the amplitude is typically a undefined variable/constant. The only case I have seen it defined for (outside of longitudinal waves from axial impact) is in the case of Rayleigh waves. In one text I have (on soil dynamics), the motion was a function of a initial amplitude…..and that amplitude was a localized displacement from a vertical load.
So I guess my question is: is this true for other wave types? Are these undefined constants typically all some sort of a function of a local displacement/deformation……possibly do to contact?
By the way, this is not considering vibration.....this is just considering the initial wave at the beginning of motion.
Thanks in advance.
In books of waves in solids e.g., Graff, there are solutions to the wave equations (say plates or rods,..) with different force terms - say excited by different simple point loads (say harmonic or impulsive point loads).
example:
Infinite rod (so standard long. wave equation describes it, no losses), with a point force in the centre exciting long. waves (F= Famp*exp(i*omega*t)*DiracDelta(x-xo))
The amplitude of the longitudinal wave is ~ Famp/(E_Youngs*Cross_Area*wave_number)
Actually, that was one of the texts I am reading. And these thoughts occurred when I got to the section on lamb waves. It is somewhat vague on this point.
Thanks for the reply.
Not sure if there is a closed solution for point force excitation with Lamb waves - perhaps there is one, but could be a bit nasty :).
Could I get some more opinions on this (my question [in bold] in the OP)? We've got some pretty sharp people here so I'd like to hear some more. Thanks.
[red]EDIT[/red]: I guess what I am after is: forgetting about the dynamic amplification (and other things that happen with complex waves at certain frequencies), is the localized [Hertzian] displacement a maximum initial amplitude? (Sort of a ceiling if you will.) Thanks again.
