Elastic modulus: steel vs brass behaviour
sunshine419
Materials
GB
Am trying to figure out the variant in the behaviour of steel as compared with brass. The elastic modulus for steel is greater than that for brass. I want to find out which woould stretch more easily and which is stiffer.
Thanks for help.
Steel is stiffer, brass stretches easier. Remember the difference between elastic and plastic deformation.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
If you take a strip of each material, fix one end, and load the other to cause it to bow (making sure that the load is light enough that when removed they will spring back to original position, no plastic deformation) the brass will defect twice as much as the steel.
Plymouth Tube
