CivilSigma
- Nov 16, 2016
- 107
The elastic sectional modulus is S= Ix/ymax.
For symmetric cross sections, the geometric (centroidal) axis = principal axis, and the calculation is trivial.
However, for asymmetric sections, the principal axis can be rotated with respect to the geometric axis.
This post here ( mentions that asymmetric sections (e.g. angles) bend about their principal axis.
So, that begs the question: What values do you use to determine the elastic modulus then? and would the section neutral axis coincide with that of the principal axis?
I think in the case of asymetric sections, I would use Imin/ymax as a conservative value for the elastic modulus of bending.
Any input is greatly appreciated.
Thank you,
CS
Thank you,
CS
