ejector pins ?!
  • Thread starter Thread starter phucxoxo
  • Start date Start date
P
phucxoxo
Guest
Hi everybody !!
I usually use the ejector pins are not the same as proe catalog, so the "Clearance cut" is different, so is there anyway to make my own catalog like the default catalog but using my standard, help me, or can you show me another good idea, thanks so much !!
phucxoxo said:
Hi everybody !!
Hi
you can download and use this extension (moldbase):
http://rapidshare.com/files/203589858/PTC.PRO.ENGINEER.WILDF IRE.B.and.W.Expert.Moldbase.Extension.v5.0_UDS.part1.rar
http://rapidshare.com/files/203590104/PTC.PRO.ENGINEER.WILDF IRE.B.and.W.Expert.Moldbase.Extension.v5.0_UDS.part2.rar
http://rapidshare.com/files/203589428/PTC.PRO.ENGINEER.WILDF IRE.B.and.W.Expert.Moldbase.Extension.v5.0_UDS.part3.rar
after install the moldbase extension, copy "config.pro" and "config.win" from (...:\Program Files\ExpertMoldbaseExtension50\text) to your working-directory (Default:My Documents)
after these, the EMX menu become add to Pro/Engineer:
http://rapidshare.com/files/288139453/1.JPG
Thanks very very much mpm_dpm !!!
I thinks EMX can slove my problem, but what a pity, my company is not using EMX ( because they have to pay more money
) so i try just to use proe to do it, i found that the ejector pins are contain in *.lay file, but i do not how to edit this file.
Hi Phucxoxo
While adding clearance cut, have you tried to edit quilt parameters the way you like.
SAAD
i tryed to download emx it coming as error
