Zouatine
- Mar 18, 2020
- 36
Dear all,
I'm designing 4 stories building steel structure on Etabs Software as you can see in the next Figure, however, I'm looking for the vectors of the first two-mode shapes of the structure in order to use them in one method that I'm using. the problem is when I look at the result I am not able to find the mode shapes vector value, it just gives the behavior of the first two modes without values. I designed the same structure in SAP2000 but the issue wasn't solved.
I'm really stuck with this part, could you please suggest me a solution for it.
thank you for your help in advance.
