Oilgas80:
There’s nothing to apologize to me for. I believe I understood the nature of your question and I tried to answer it appropriately. As a ChemE, I’ve been fortunate in working around the petroleum production arena in several manners. I’ve worked for companies who designed and fabricated 3-phase oil-gas separators. The name, 3-phase, is a misnomer I believe, because only 2-phases are involved: an oil+water liquid phase mixture and a hydrocarbon gaseous phase. Nevertheless, that’s what they’re known as. I’ve also done process design around the production coming out of such vessels. I’ve never designed them and I don’t believe an average engineer gets much of a chance to do so unless he/she are working for the very specialized companies who do this specific type of design and fabrication. There are maybe 5 to 10 such credible or recognized companies in the North America. I say “recognized” because a lot of faith and confidence is put on their back to produce the specified and desired product. Sometimes, depending on circumstances, some design liability is involved – depending on contractual arrangements and terms. Therefore, the subject of “efficiency” is not discussed until one gets into a contract with such a company. Of course, if a purchaser is going to hold the designer’s feet to the fire, the price and contractual terms go up proportionately. After all, fair is fair.
Sooner or later particulate size comes into the picture when the term efficiency is employed in this type of separator. And that’s where the “problems” start. If you are linked or deeply immersed in the oil business, you must have had some contact with or own a copy of John Campbell’s two volumes: “Gas Conditioning and Processing”. If you haven’t read Volume I, I strongly recommend you do so, especially Chapter 8, “Process Vessel Specification”. Campbell deals with this subject in a manner that is more specific and practical than even the GPSA does – which is admirable. On separator sizing, John is very frank and direct: “Do not be naïve. Most published capacity curves are for ideal conditions. Use them cautiously.” He further adds: “It is almost impossible to measure particle sizes in plant service.” I certainly agree. He goes on to deal with the subject of efficiency in a general and unspecific manner. How can you talk of efficiency of particle removal when you can’t measure the particles? And even if you could, the particles of liquids continually change in diameter as they progress in a process line. It is a difficult subject for any practical engineer – except for an academician.
Two persons who claim to have measured and tabulated oil-gas separation are Dr. W.D. Monnery and Dr. W.Y. Svrcek (University of Calgary) in Canada. However, I believe they get the particle size “identified” by back-calculation, I think – not by actual measurement. I have a report on a series of tests done by them and I believe you can download it from the Internet. I don’t have any website identified, but you can try Google.
That’s as close to talking separator efficiency as I’ve been able to identify. I’m sorry if I can’t give you any more information. It’s not a very easy subject to talk about or much less to try to measure in the field.
