An extremely interesting question. From only a practical point of view, I can tell you that glass is used in marine applications such as sea strainers, which are devices that filter incoming seawater for cooling purposes. Sea strainers have been used on boats for many years. I don't know exactly how long they've been used, but I have personally serviced sea strainers that have been in use for well over 20 years. Interestingly, sea strainers not only "live" below the sea surface, (albeit in an environment with air on one side), they also frequently have a significant flow of sea water through them. Glass in itself is a peculiar material, as, I am informed by engineers, it is at almost all times a liquid. Glass in a vertical application, such as a window pane, will eventually flow to the point that it is thinner at the top than at the bottom. That will take many years to occur, but it can be verified easily with a micrometer and any pane of glass in an older house. Given that glass in it's usual solid appearing state is a slow moving liquid, one does have to wonder what the effects of another liquid in motion in direct proximity has upon it. Does it erode? Does it "Ripple" like a sand dune?
I hope this doesn't raise more questions than it answers, but it is very curious. If it is of any help at all, my experience is that glass in it's "pure" form as well as it's "Composite" form (fiberglass) is as nearly absolutely inert in seawater as anything can be.
So, why do you want to know?
Dirk
