Am trying to solve a problem with abnormal tire wear that seems to be stumping everyone... Have found my favorite sticky tires ever but after only 12k miles they've worn dangerously only on the inside 1" or so on both sides and nobody seems to know why... Tire wear is normal otherwise on front and no problems with the rears. Looks for all the world like excessive negative camber but it (and all other alignment params) are within spec (-1 deg on camber). Only other factor is that I installed these tires on Saleen 18" rims (which, since it's stock on those cars shouldn't cause problems) and that may have changed my wheel offset. Is it possible that the wheel offset of those Saleen rims has altered my scrub radius adversely to the point where these Neova Advans won't live as long as they should? Or do you think I should look elsewhere??
Any and all suggestions welcome... I just want to figure out a way to make these tires last as long as they ~should~ !!
