AlexREI
- Nov 19, 2008
- 7
Does anyone have a good anwser for how cambering a beam effects it vibration characteristics (in composite steel). The AISC floor vibration guide uses the equation fn=.18*sqrt(gravity acceleration/deflection)) to get the natural frequency of a particular beam or girder.
When a beam is cambered, your deflection will be much less and therefore the natural frequency will be higher. I'm not sure if this is the appropriate value to use though.
If the total uncambered deflection is used, the natural frequency will be lower and the beam would have to be larger to be greater than the forcing frequency.
Does anyone have an opinion on how the natural frequency should be calculated w/ camber? Thanks.
