JimAttrill
New member
From the Owner's Manual, page 3:
"Anything that improperly causes a difference in individual wheel speeds, such as mismatched tire diameters due to differences in tire wear or tire pressure ... can cause the NoSpin differential to deliver power to only one side of the vehicle ... "
This comes with a picture to show how you should measure the diameter of each wheel and adjust tyre pressures to get these equal. However, I think that this reasoning is suspect. What is important regarding wheel speed is not the diameter of the wheel/tyre but the circumference. Tyres of different sizes or wear will alter the circumference whereas unequal loading or pressures will not. If one thinks of a tracked vehicle as an extreme example, the distance from the ground to the centre of the driving wheel will vary, but the length of the track cannot, just as the 'length' of a tyre cannot, especially with the modern steel-belted radials. So a wheel with a deflated tyre will go round at the same speed as a wheel with a tyre at the correct pressure.
I am not saying that driving with under-inflated tyres or unequal loading will not affect the steering, but that the effect will not be caused by differential wheel rpm as the wheels will go round at the same speed.
I e-mailed Tractech pointing out this error in their manual but never received a reply.
