EFFECT OF LONG HOLDING TIME ON SA-516 70N DISH END NOMALIZING
staticmh
57
Hi Folk! Good Day!
This is regarding the 2:1 Ellipsoidal dish EFE & end heat treatment, dish end nominal thickness is 20mm and material is SA-516 Gr. 70 N.
As per the code clause UCS-79 (d) is applicable, which states “if dish end formed with cold forming and determined the extreme fiber elongation(EFE) higher than 5% then heat treatment shall be performed as per UCS-56 temperature & holding time”
But over and above, client specification of SHELL DEP is also applicable, which states that “in case of dish end cold formed and determined the EFE higher than 5% then NORMILIZING shall be performed with following temperature (850 to 960 deg C)”
As per UCS-56:
Dish end Nominal thickness = 20mm
Holding minimum Temperature shall be = 595 Deg C.
Holding minimum time duration = 1 Hr / 25mm
Holding minimum time duration per mm = 2.4 minute / mm
Now as per Nominal thickness holding time = 20 x 2.4 => = 48 minute.
As per Shell DEP:
Holding Temperature shall be = 850 to 960 Deg C
Holding minimum time duration = Need to specify, as SHELL DEP is silent on Holding time.
Question no-1 : Whether Holding time for normalizing shall be followed as per UCS-56 or as per material test report (MTC)?
If we see on material test report, it is calling for 1.75 minute / mm and if we calculate as per MTR then it shall be 1.75 x 20 = 35minute.
Question no-2 : Please advice material specialized person & vessel design engineers on above clarification. that what can be the effect on original material properties due to higher holding time considering for normalizing.
What is the actual % fiber elongation?
I suggest to use the MTR. No problem with higher holding time.
@r6155
Its higher than 5%.
What will happen if we maintained higher time than MTR?
@ staticmh
Waste time and money.
staticmh, you will want to make sure your material meets specified mechanical properties. You should be pulling the mechanicals anyway. See UG-85, UCS-85 and related references.
Mike
Staticmh,
Every specification/standard have its own twists and turns and you will notice some variances. Usually, in a project, Customer/project specification will govern. In your case, it's shell DEP. My advice is the following:
1. Raise a Technical RFI(Request for Information) to the Client stating that Normalizing for the ellipsoidal dish head is required and what is missing.
2. Recommend UCS-56 holding time.
3. Get it approved.
In this way, you are covered and is following the Client's rule.
GDD
Canada
