I perform random vibration analysis for a small company utilizing cast aluminum housings which are typically piloted into to a gearbox of some sort and mounted via a bolted mounting flange. A recent housing has the main body outside of the gearbox and is mounted via a bolted flange. There are various masses/components attached to the body which creates an overhung mass cantilever beam type system. Whenever I perform an analysis I constrain a volume 1.5 times the mounting bolt diameter and apply base excitation. When I do this the results are always the housing mounting flange in between the bolt locations either lifts off of the fixture plane, or penetrates into the fixture plane. This has always been conservative when compared to fixing the entire mounting face, and we have been able to make modifications to the housings to facilitate passing the vibe test with success. This is however not what will actually happen in application as the housing cannot penetrate the fixture plane (though theoretically it can lift off slightly). My question now is is there an effect on the natural frequencies as a result of this contact between the housing and fixture and can anyone provide some insight as to ways of handling this effect? I keep thinking of a guitar string which does nothing when something obstructs its motion, yes it is free in one direction but not in the other and therefore the mode does not exist (at least as I understand anyway). I know that this is more along the lines of a wave rather than a modal analysis but hopefully gets my thoughts across. Is it possible for a mode to exist if half of its motion is prevented?
Again any help would be appreciated and thanks in advance,
- J -
- J -
