Hello all,
I am using NX since 13 years, and now, keeping short steps in NX PMI. ( current NX version 9 )
I wanted to know, can I edit the PMI Dimensions in drafting mode?
I am using master model concept, and the PMI dimensions are defined in the Part model, there is an assembly file, and a non master document for that assembly file which contains the drafting sheet, in which I have the views, created in that Part model with PMI dimensions.
Things I prefer to change is the tolerances, GD&T's, Datum symbol placement (Shift + move doesn't move unlike in native drafting) and added notes through PMI.
The reason I ask is, if there is any change in the drafting file which is not affecting the part file, then in the present case, I must also revise the part file, unlike doing it without PMI, I could have just revised the Drafting file only. Revising the part model has consequences of change of CAM program too, that is why I wanted to know whether I can Change few things in Drafting file using PMI dimensions and notes.
Creating the same dimensions again in the drafting sheet would be duplicating work. So please help.
Pradeep.
Pradeep.
