editing dxf drawing error
  • Thread starter Thread starter -
  • Start date Start date
Guest
How do I edit an error on a specific line of the text
file for a dxf file to repair the file for insertion?
Message reads "No layer specification for this object on
line 4432".
Open the DXF in Word, scroll to the offending line, modify and save as text only format. Of course, you will need to know exactly what to put there to fix the problem, and I cannot offer advice for that, since I am not familiar with the drawing you are attempting to repair. There are other alternatives however, You can download IntelliCAD from htp:// and open it from there, IntelliCAD opens files that AutoCAD won't and allows you to save them to just about any version. Another alternative is to go to and download the dconvert program to convert DWG to DXF and DXF to DWG. You can then use the recover command in AutoCAD to fix the offending error.
If you could e-mail me the file at:
steveasmith2000@yahoo.com
I'll try to see what, if anything,
I can do with it.
Regards, Steve Smith
Product Engineer
Staco Energy Products Co.
As Striker says, go to the said line, look for layer name a few lines above or below it, then to a global Find/Replace, replacing that layer name with layer 0. This ought to work without knowing the exact structure of a DXF file.
You can also do a recover on the .dxf file under "drawing utilities" on the "file" menu. Your particular problem is usually easily fixed by the parser. I wouldn't reccomend editing the file by hand unless you are accustomed to the data structure
