itaylor
Automotive
- Apr 1, 2008
- 38
Can I control the 'Edit Copy' option in the Enlarge Surface dialog in NX9.
If I'm reading it correctly...
The Help states that by deselecting the Associative Freeform Editing Modelling in preference then deselect 'Edit Copy' in the Dialog I can edit a surface and regardless of whether it is associated to another feature it will modify the existing surface and convert it to a sheet body. (unless it is the Face of eg... a solid, then I would expect a new feature)
I do not want to create a new feature, I want to enlarge the existing
I toggled it off in Customer Defaults (and restarted NX)
Both options add a new Elarge Surface.
I understand the logic in the command, ie if it is associated the a new feature is created, but I want to choose when it does this ... like it was in NX8.5
Automotive
EDAG Engineering Germany
NX9.0 TcAE 10
Automotive
NX9.0 TcAE 10
