Economic dealing with H2S separated from Amine Unit
arahmans
Chemical
EG
Any one has former experience to advice;
Which will be more economic, converting H2S to elemental sulfur or to Sulfuric acid?
Thanks,,
Do you have access to an acid plant?
What is the relative value in your local of S and H2SO4?
What is the required energy input for the two options?
Dear EdStainless,
Thank you for your response,
I have not access to an acid plant.
S price = H2SO4 price * 2.59
I do not energy inputs.
If available, what is the relative capex & Opex of SRU to Sulfuric acid plant in the case of the same H2S feed to both plants?
For the current case , Acid Gas Stream as following:
Unit Acid Gas Stream
Vapour Fraction 1
Temperature C 50
Pressure psig 5
Molar Flow,kgmole/h 71.4113788
Mass Flow,tonne/d 62.22920921
Liquid Volume Flow,m3/h 3.87925353
Composition
Mole Frac (CO2) 0.158110893
Mole Frac (H2S) 0.797398247
Mole Frac (Methane) 0.000479617
Mole Frac (Ethane) 0.00030907
Mole Frac (Propane) 0.000206551
Mole Frac (i-Butane) 1.14E-05
Mole Frac (n-Butane) 4.88E-05
Mole Frac (i-Pentane) 0.005704713
Mole Frac (n-Pentane) 0.005464379
Mole Frac (n-Hexane) 0.005208501
Mole Frac (Mcyclopentan) 9.91E-06
Mole Frac (n-Heptane) 0.003617801
Mole Frac (n-Octane) 0.000777642
Mole Frac (n-Nonane) 0.000246288
Mole Frac (n-Decane) 1.71E-05
Mole Frac (H2O) 0.022389078
Mole Frac (MDEAmine) 7.62E-25
Thanks & Best Regards,,
I would start by contacting the companies that build this equipment. There are a handful world wide that design and build acid plants, likewise there are ones building pure S facilities.
