I am trying to design a mechanism that will lock two rollers against each other. One roller is driven by a motor and its position is fixed. The second roller is a pinch roller that needs to contact the drive roller during operation so it is driven. The pinch roller also needs to be able to be adjusted away from the drive roller to run a label web through. Both rollers are 8 inches long and need to fully contact each other along the entire height (driven roller is rubber and pinch is knurled aluminum).
Currently this is done with constant force springs on the pinch roller and a threaded adjustment that brings the roller into and away from the drive roller. I would like to simplify this and I think it can be achieved with an eccentric cam, just not sure the best way to do this.
One idea I had was to have a pressed pin mounted eccentrically at each end of a rod. The pins would be supported by bushings on top and bottom plates. A knob "keyed" with the pin would be turned which would then rotate the rod. The pinch roller would be mounted on the rod with bearings to allow it to rotate. The only thing I'm not sure about is if the rotating "eccentric cam" so that the pinch roller is pressed against the drive roller would hold it there. I feel that it would want to turn eccentrically on its own away from the drive roller. Something to lock the knob in place could fix this.
Would my idea work? Any other suggestions, would also be much appreciated.
