JAG-E
- Mar 8, 2018
- 17
I have been asked to assess an existing piece of lifting equipment. I have analyzed many welds but this is a configuration I cannot find a method for. The load is eccentric. Plenty of examples for that as well as computer applications, but not with this weld to load orientation. It appears to me the leading tip of the weld will be highly stressed, limited stress distribution, and would tend to "unzip". The weld group CG approach suggests a rotation of the cantilever about the weld group CG. Here the CG is in the center of single weld on each side. I think the tip of the weld and some limited depth into the weld, moving right to left would take all the bending load. I thought applying stress=Mc/I at the beginning of the weld using I and C of the two weld cross sections. Any suggestions or key words to search on would help.
Joe
PS There is no indication in preview if the image uploaded. If there are two they will be the same. If none I will try again to add the image.
Joe
